May 13, 2006, 16:46 |
Bubble Dynamics & VOF
Hi fluent experts,
Is it possible to incorparate bubble dynamics behavior using VOF model? I am trying with the venturi model & introducing spherical bubbles at inlet.please share your suggestions to me. Any help would be very much appreciated. regards, Pranav |
May 13, 2006, 17:50 |
Re: Bubble Dynamics & VOF
yes, dynamics of bubble motion can be captured using the VOF model. What is this venturi model?
May 14, 2006, 10:15 |
Hi mln,
My computational domain is venturi. I am injecting a spherical air bubble at the inlet of geometry. Primary Phase of my analysis is water.The main aim of this study is to predict the variation in temperature of the bubble while travelling in different cross section of venturi. Is it possible to enable Energy Eqn and make secondary phase is compressible?. If so, where can i get the variable property of air with respect to pressure & temperature? Any help is highly appreciated Pranav |
May 14, 2006, 10:30 |
You can define a mixture phase and use species transport. I think Fluent will allow for at least one compressible phase. Check the manual.
May 15, 2006, 03:34 |
Hi!
I think that what you try to do is wery interesting but also very hard. There was a paper of cfd simulation including thermal effects at the CAV2003 conference (just write cav2003 in google - you´ll find a link to the papers there). But there they used a different approach of modelling - the barotropic cavitation model. You´ll probably also not get far with vof and bubble dynamics (reyleigh plesset equation) because you´d need a very dense mesh for that - cell size 1/10 of the bubble size...that´s approximatelly 10^-5m (or even less in the beginning and end stage of bubble evolution). I hope I helped a bit... If you have any questions about cavitation modeling i am heppy to help, just write me an email - i did a lot of work in this area (but none considering thermal effects. By mateus |
Bubble coulmn and VOF method (interFoam) | voingiappone | OpenFOAM | 14 | June 26, 2012 20:13 |
VOF single bubble rising velocity! | Lincoln | Main CFD Forum | 3 | April 10, 2012 10:04 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
Query on VOF for Bubble rise | Vamsi | Main CFD Forum | 0 | December 22, 2005 00:02 |
Bubble Dynamics in Fluent | Gautam | FLUENT | 0 | July 12, 2005 12:42 |
