how to add source terms to a cell?
Old   May 13, 2006, 11:34
Default how to add source terms to a cell?
lily
Can anyone give some hints about how to add a fluid injection to a cell as source term? thanks a lot.
Old   May 15, 2006, 11:56
Default Re: how to add source terms to a cell?
AdN
if it's a constante source term, you just have to go in boundary condition panel, select the fluid where the source term will be added, and after select source term... And no you can add a constant source term... If your source term is variable, you have to write a UDF...
If you have another question about this subject don't hesitate...
Old   May 17, 2006, 21:31
lily
Thank you so much for replying my question. I have two species in the system, and i want to add the second species under the wall, it's like adding an injection at a point. i only want to add the injection to a single cell. Could you give me some hints about how to specify that cell? Thanks a lot.
Old   May 18, 2006, 03:07
AdN
If you want to do that, why do not use the injection model in fluent. and in your pb you can choose a single injection. And with that you can choose the coordinate of the cell. But if your pb is more difficult, and need to introduice a UDF, you will have to use centroid to choose your cell (for more detail see the UDF book.
P.S. for the single injection, there a tutorial. It can helpl you...
Old   May 18, 2006, 19:33
lily
but the second species is also gas, injection is for injecting particles.
Old   May 24, 2006, 05:38
James
Hi AdN,
Do you have an idea whether Fluent has any UDF that considers liquid injection of fuel that is not steady......but according to a particular function like say a step function?
counting on your assistance.
James
Scalar Field Source Terms tidal_Tom OpenFOAM Programming & Development 1 March 23, 2011 06:25
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
UDF Source terms not producing expected results... Emmanuel Resch FLUENT 0 July 31, 2008 15:55
UDF - source terms Fred FLUENT 2 October 11, 2005 21:53
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
