Cooling simple 3D geometry problem
Old   May 12, 2006, 10:03
Default Cooling simple 3D geometry problem
Luk
Dear all, I am very fresh Gambit/Fluent user and need to solve a CFD simple problem on the lend computer. My geomery is very simple: I have (created in inventor and exported as .stp) solid it and cylinder matching this hole that symobolics volume of water. I want to simulate cooling of the solid by water that flows through it. I am playing with this for a long time but noticed no interaction between solid and fluid despite patched temperature difference. I guess that problem is in meshing/setting boundary conditions of the "pipe". Can anyone describe way to mesh it properly in gambit? I tryed to do: - load a solid and subtract a cylinder (to get a solid with hole) and than add a cylinder as a second volume. After that set BC's and mesh - load a solid and cylinder without subtracting and mesh it.
None of these tryes give any "cooling" result in final solution (nor Fluent notices any shadow faces). I would be very grateful for any help, With best regards, Lukasz
Old   May 12, 2006, 10:09
Default Re: Cooling simple 3D geometry problem
Luk
Sorry for mistakes, in second line should be "solid and cylinder". The mistake is because I was trying to make solid with hole to avoid subtraction in Gambit.
Old   May 12, 2006, 10:24
philipov
You do not need the cylinder. Just set the inner surface of the solid to be BC as constant temperature (the temperature of the fluid).
Old   May 12, 2006, 10:39
Luk
Dear Sir, I am not quite sure If I understood You well. I assumed that fluid (Water) will be heated by surrounding hot block (which, in turn will be cooled down). So I though that I need fluid zone inside. In the end I am interested in cooling ratio of the block and leaving water temperature as a function of time.
Luk
Old   May 12, 2006, 10:47
philipov
If you want , send me a scheme of your task and I'll write down what can be done. As I understood you want to see temperature of the fluid and temperature of the solid also. If you do not have fluid flow, then just write: M(fluid).cp(fluid).(t1-tx)=M(solid).cp(solid).(tx-t2)
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 05:53
1D thermal stress problem simple barrodbeam newsboost OpenFOAM Running, Solving & CFD 3 January 2, 2009 16:12
Problem in Initializing Blocking for 2d geometry nitin Dewangan CFX 6 October 24, 2008 02:03
Meshing Film cooling geometry Janendra Telisinghe CFX 1 January 31, 2006 07:16
? Simple CFD problem Davy Main CFD Forum 0 August 21, 1998 07:19
