mass flow rate----------
Old   May 9, 2006, 02:22
Default mass flow rate----------
mech
hi i am simulating constant area channel flow. It is compressible and follow ideal gas law. I define pressure inlet and pressure outlet. inlet mach number is 0.07 and oulet mach number is 0.15. But after simulation inlet mass number goes down to 0.03 and outlet 0.07. To overcome this problem I want to fix up outlet mass flow rate. But using text command I can not activate it. It gives error:eval:unbound variable Invalid Integer etc. So can anybody suggest me. Thank you in advance. Mech
Old   May 12, 2006, 04:54
Default Re: mass flow rate----------
ravindra
hi, if you want to consentrate on mass flow rate , you can try by changing pressure inlet to mass flow inlet and try to solve problem. if you know mass flow rate. in case of pressure inlet only you have to give total and static pressure (if you know) . i am not able to understand how you have given mach no at inlet and outlet. by
ravindra
Particle Injection Mass Flow Rate and Position leonozx FLUENT 3 March 9, 2018 10:58
CFX turbo - Mass flow rate Vashishth Patel CFX 7 April 3, 2014 21:33
Mass flow rate at the outlet tejasvikrishna FLUENT 2 May 25, 2013 03:42
negative global mass flow rate Gimli FLUENT 0 April 21, 2006 08:17
mass flow rate error Masood FLUENT 0 May 22, 2005 01:32
