May 8, 2006, 06:30 |
Does the wall BC set k & e to zero?
Hi,all!
I use the ske model and set the BC as "WALL" for some solid boundarys. But after caculation I ploted turbulence kinetic energy(k) along these "walls" and found them not equal to 0. Why??? I tried adding some source terms to the momentum equations, but the caculations diverged soon. I checked the values of k and found them quite large somewhere on the wall. I think this resulted in the divergence. Can anyone tell me how fluent set the "WALL" BC? If I change the boundary condition "wall" to "velocity inlet" and set velocity,k and e to 0, is there any problem? Any help will be very appreciated! |
May 8, 2006, 13:39 |
Re: Does the wall BC set k & e to zero?
The default boundary condition for a wall is no-slip, so the immediately adjacent velocity is 0. Maybe if you set the walls to be slip walls (in the wall boundary condition panel) you would get nonzero k and e.
May 8, 2006, 22:53 |
The problem is that I want k and e on the wall to be equal to ZERO but FLUENT actually don't set them to zeros in the default WALL boundary condition.
December 10, 2010, 12:49 |
Marta Lazzarin
Rep Power: 17 |
Hi guys!
I am trying to create a boundary condition in Fluent similar to the wall+source which can be found in CFX. Do you know if it's possible for me to use any kind of udf to do this? In particular what I would like to do is to add a mass flow rate source, instead of using the mass flow inlet boundary. This is because i need to perform some other operations which are only allowed on walls. Thanks a lot in advance! Marta |
Thin Wall Heat Transfer BC for rhoSimpleFoam | swahono | OpenFOAM Running, Solving & CFD | 12 | October 4, 2013 12:49 |
UDF for wall slipping | HFLUENT | Fluent UDF and Scheme Programming | 0 | April 27, 2011 13:03 |
how to set up wall function in bubbleFoam | adouchihiitoko | OpenFOAM Running, Solving & CFD | 5 | November 5, 2010 06:59 |
Parallel implementation of k-e model | Niels | Main CFD Forum | 6 | June 27, 2008 15:31 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
