May 4, 2006, 07:36 |
Problems with gambit meshing
I'm new to cfd and am having trouble in implementing a mesh made in gambit to use in fluent. I have 5 different faces which all have different mesh sizing on all edges, as summarised below, or similar to http://130.149.35.79/downloads/publi...7048-FINAL.pdf page 8. ___________________ | 200*5=1000elem | |__________________| | 400*10=4000 el | |__________________| | 800*10=8000 el | |__________________| 0.8m | 400*10=4000 el | |__________________| | 200*5=1000 el | |__________________| 8metre The 2d box is to model wave behaviour where the mesh is exagerated in the region of where the wave is acting between the interface of air and water. My problem occurs in fluent. All of the internal edges in fluent are recognised as walls though i just want fluid between the 4 outer boundaries. Help please! Thanks in advance Shane |
May 4, 2006, 08:18 |
Re: Problems with gambit meshing
I think you have edges which are not connected. check the connectity
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 06:59 |
is free meshing or mapped meshing is best for flow problems | shanu | Main CFD Forum | 0 | February 18, 2010 12:58 |
Meshing problems using Gambit | Vianney | FLUENT | 4 | May 30, 2009 04:45 |
meshing a fan using gambit | tony | FLUENT | 1 | February 15, 2008 01:28 |
Gambit: too long meshing time! | delsolman | FLUENT | 1 | January 29, 2008 20:06 |
