May 3, 2006, 05:12 |
setting boundary condition in journal file
Hello.
Thanks for your interest in reading my question: I am new in using journal files. I am using FLUENT in Windows, and I used the sample of journal file in the manual and I could apply it in my case file easily. But when I wanted to set/change the velocity magnitude in velocity-inlet BC I dont know how to that; I tried this but it didnt work: . . ; setting the velocity to 2m/s /boundary-conditions/velocity-inlet vi 2 . . Any idea? how can I set the turbulence intensity in this boundary type too? Thanks, Maz |
May 3, 2006, 20:08 |
Re: setting boundary condition in journal file
Maz,
It is just so much easier to setup your case and then write a simple journal file for submitting jobs in batch mode. |
Trouble with journal file reading wall boundary condition | jwillie2000 | FLUENT | 0 | September 7, 2010 13:02 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 07:43 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 05:26 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
Problem setting boundary condition from file | Antonis | CFX | 1 | September 11, 2006 17:53 |
