Unit of UDF
Old   May 2, 2006, 10:04
Default Unit of UDF
AdN
Hello First, thank you to take time for reading this. I need some informations: I'm using a UDF that return a Source term (a mass). In the book, they said that the unity of the mass is : kg/m3-s... I'm in an unsteady simulation, and I'm injecting a constant mass ( in my function for exemple source = 500.) Does it mean, that if I had a time step of 0.01 seconde, my function will inject 5kg? Hope my question is enough clear. Thank you
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 22:38
UDF unit and FLUENT output saifulraju FLUENT 4 September 21, 2010 23:22
Control dynamic mesh with different length unit by UDF nchuche FLUENT 1 June 29, 2010 11:33
Unit in UDF Tajul FLUENT 2 January 25, 2006 22:04
