April 29, 2006, 06:02 |
mixing plane problem
sir/madam,
i am student of Mtech turbomachines from s.v.N.I.T. surat, Gurat state, India. I am doing my Mtech project work and i have to do analysis of axial flow compressor in Fluent 6.2. Problem : I have created inlet flow and exit flow domain and blade domain with blade at Center both for rotor and stator. As my rotor is highly twisted, for stage analysis i have taken two blade domain and one stator domain. I have generated mesh and transport to fluent 6.2 all boundary condition i have given properly. mixing plane generated . here only i am facing problem mixing plane is generated but it is not exchanging temperature from rotor to stator and back . i am getting all relative vectors in direction of flow . i am getting mass flow out of stator . upto rotor outlet rise in total temperature is there. At stator inlet it is taking temperature as 303K what i have give at inlet of rotor. rotor outlet also i am getting same temperature . due to this i am unable to get efficiency in turbo report. also as back pressure (static) rising mass flow reduces but Pressure does not increases. so please help me in this regard so that i can solve this proble with in small time to complet my project work . thanking you ravindra bankar |
Total mass flow/flux through a plane problem | nwalters | FLUENT | 1 | December 18, 2010 13:23 |
Air & water mixing problem | praveenkumar | FLUENT | 0 | April 15, 2010 03:14 |
Unable to switch from Rotating Reference Frame to Mixing Plane | bwg | FLUENT | 0 | July 10, 2009 15:56 |
Turbine stage mixing plane calculation | Knut | FLUENT | 0 | December 4, 2007 13:46 |
MFR and mixing plane boundary . | Mica | FLUENT | 0 | January 26, 2007 10:39 |
