flapping wings/fishlike propulsion
Old   April 26, 2006, 06:12
Default flapping wings/fishlike propulsion
joegi
Currently I'm using an academic software to simulate flappings wings. At this point I would like to compare my results with the results obtained with another software, for instance fluent. I'm wondering if it's possible to do this kind of simulation on fluent.
In a few words, what I need to do is to move my geometry up and down and make it rotate around its spanwise axis, just to simulate the kinematics of a wing. Is this possible in fluent?
I really appreciate your comments and suggestions,
Cheers,
joel
Old   April 26, 2006, 06:31
Default Re: flapping wings/fishlike propulsion
Luca
Yes you can by using the dynamic mesh in Fluent. I deal with fluttering wings but I do not the order of magnitude of your displacements. I'm interested in how you deal with flapping wings with your own code. If you want to contact me my mail is: lucav79@alice.it Luca
Old   April 28, 2006, 05:11
kelvin
this is what I am doing now. my thesis is to simulate the bionic propulsion with FLUENT.
Old   April 28, 2006, 10:02
joegi
Can you share with us some information?
Old   May 1, 2006, 13:37
Astozzia
hey there,
I'd be very interested in getting informed about teh way you tackle this problem.
I a simulating the kinematics of a flapping wing also, using Fluent. I am resorting to a compiled UDF and dynamic meshing.
However, whenever I lauch the simulation, there sems to be negative volumes at the first time step...
Does anyone have a clue? Or did anyone encountered the same error? by the way, my mesh is fine before any iteration.
Thx a billion! Astozzia
Old   May 12, 2006, 05:12
desantis
the reason for the negative volumes is that ur time step size is too large. reduce ur time step size. by the way, my msn: [de_santis1981@hotmail.com] i really appreciate anyone who interested in the bionic propulsion to communicate with me.
Old   May 19, 2006, 03:23
V. Malolan
Hello !
I am trying to use Fluent for flapping wing studies. I wish to know if RNG K-e model with enhanced wall treatment functions will be OK. If any other simpler model will suit it may be better (because unsteadiness eats away all the time and computer resiurces)
Old   May 19, 2006, 03:29
desantis
In my calculations, i found K-w model is much better.
Flapping wingsfishlike propulsion joegi OpenFOAM Running, Solving & CFD 5 December 23, 2011 07:13
flapping wing analysis doctsh FLUENT 0 February 17, 2011 22:43
best software for the simulation of propulsion hanman Main CFD Forum 3 August 26, 2008 09:49
UDF for flapping element behind a cylinder Ravi FLUENT 0 June 14, 2006 03:27
tracked vehicle in-water propulsion ming_hunter Main CFD Forum 0 October 30, 1998 23:35
