bluff body and Y+
Old   April 25, 2006, 14:13
Default bluff body and Y+
justin
Hi,everyone. I am studying wind environment around buildings. The problem is how to easily set the first cells aroud the bluff body to make the y+ at the desirable range (30~60). As the pressure and stress on the surfaces are variable, that means the first cells should be different. Now I used the structured mesh. After convergence, the range of y+ on the suface was from 40 ~ 1000. If I use y+ grid adaption, the range of y+ droped down slowly ( once about half decrease)and every convergence spend a long time.
Do you have any strategies or suggestions?
Thanks in advance Justin
Old   April 26, 2006, 11:07
Default Re: bluff body and Y+
Chandra Murthy
y+ will be very important parameter to look in, when it is required to model heat tranfer to the walls or to capture the boundary layer very accurately. in your case (wind environment around building), does it required to control the y+ in such a close manner. Otherwise, if there is something else, write it.
Old   April 26, 2006, 12:08
justin
thanks for your reply. But I still don't know how to make this value around bluff body pefect in Fluent. the range of the value is too large to control easily. sometimes the lower is above than 30, but after adaption, part of the values will be lower than 30. I heard that y+ in CFX can be defined and you don't worry the mesh density leads to the y+ less than 30. It looks like fluent doesn't have this function.
This problem cost me a long time. Now I am so disappointed. please help!!!
Old   May 4, 2006, 21:13
Naresh
hi
I had this Problem too. Just try with boundry layer, and type firstat "first row a" =2. U will see what happened in the near of the wall, if u click the wall line. Just try.
abhay
Bluff body used for diffuser testing lemat1 Siemens 0 December 5, 2009 10:11
temperature going negative behind a bluff body Sourabh Phoenics 6 December 1, 2007 19:50
Bluff Body krithiga Siemens 4 November 7, 2006 16:45
UDF for lift force on a bluff body sawa FLUENT 2 April 11, 2005 04:06
triangular bluff body Pratap Main CFD Forum 0 April 5, 2004 03:23
