April 24, 2006, 17:23 |
Linear Temperature Profile
I am a newbie in CFD and doing calculations on a closed cubic cavity. The top wall is defined as cold and the bottom wall is hot. Now I want to define linear temperature profile around the four side-walls. How to input linear temperature profile ? Please help.
April 24, 2006, 17:51 |
Re: Linear Temperature Profile
You can use either a UDF for boundary profiles to achieve this. Check out the Fluent UDF example on specifying a parabolic inlet profile. Your problem could simply follow a similar structure.
UDF for linear temperature profile across the hemispherical surface | tshv247 | Fluent UDF and Scheme Programming | 1 | October 3, 2011 13:44 |
Appling a linear temperature profile to a surface | safikhani_hamed | FLUENT | 0 | December 8, 2010 15:59 |
Help please! UDF for Temperature profile in 3D | subhankar_bhandari | Fluent UDF and Scheme Programming | 2 | August 16, 2010 09:37 |
solution diverges when linear upwind interpolation scheme is used | subash | OpenFOAM | 0 | May 29, 2010 02:23 |
temperature profile on boundary | sivakumar | FLUENT | 5 | November 24, 2002 01:58 |
