negative volume 2d
Old   April 20, 2006, 12:43
Default negative volume 2d
AJG
I'm meshing a square domain with a hole in the middle. Is 2d and very simple, but when I check the grid in fluent it tells me that I have a negative volume! what can I do?
Thanks
Old   April 21, 2006, 04:29
Default Re: negative volume 2d
gernot
Is it axysymetric? Because then you must not have a grid with negativ y-cordinates.
Old   April 21, 2006, 05:33
Claud
Hi, the best thing is to work only in positive directions for x- and y-axis. In case you want to rotate your square, then your rotation axis has to be the x-axis! Claud
Old   April 21, 2006, 05:42
philipov
I had a similar problem. Increase number of nodes and try different meshing scheme.
Old   April 21, 2006, 07:52
Rajesh
This is more common when you have highly curved regions in your domain. In this case you have a circle where the grid may generate the negative volume on it. This can be elimintaed by dividing circle into more no. of segments and then mesh it. You need to try with diffrent grid spacings also.
regards
Rajesh
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
