energy source
Old   April 20, 2006, 11:22
Default energy source
Universtiy Paul
I'm creating a custom energy equation for Fluent to solve. Essentially it is the standard density * velocity * Change in enthalpy / displacement. However I need to subtract a calculated amount of energy.
The only way I can do this is by creating an energy source; source = C_R(c,t)*C_W(c,t)*????-(j*Ey);
how do I include the differential and will it actually work, current attemts result in max/min temps occuring in thousands of cells.
Can anyone help?
Old   April 20, 2006, 13:13
Default Re: energy source
wicwawa
sorry, part of your text i could not see correctly.
You may try C_R_G(c,t),it is the differential of density
hope it can help
wicwawa
Old   April 20, 2006, 15:38
university paul
If I use C_H_G(c,t)will that correctly find the differential of Enthalpy. I looked it up in the UDF handbook however wasnt sure.
Old   April 21, 2006, 16:15
wicwawa
sorry , i never use C_H_G(c,t),i am sure it is no problem about C_YI_G and C_R_G, since i have used then. they are differentials in three directions.
wicwawa
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
UDF Scalar Code: HT 1 Greg Perkins FLUENT 8 October 20, 2000 13:40
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 04:43
