journal file with variable in a while loop?
Like Tree8Likes
Old   August 13, 2014, 18:22
Sashankh is on a distinguished road
Hi Max, can you please send me the file if you still have it. My email is srao7@tigers.lsu.edu. Looking forward to using it. Many Thanks.
Sashankh is offline   Reply With Quote
Old   November 18, 2014, 11:05
kaeran is on a distinguished road
Hi Max,
Please send me the journal file, if you still have it. It would be really helpful.
E-mail ID: ia2010@thi.de
kaeran is offline   Reply With Quote
Old   December 19, 2017, 13:27
Muhammad Ali Uzair
m.uzair is on a distinguished road
Does anybody still have this file? If so, please e-mail to muhammadali.uzair@poliba.it
m.uzair is offline   Reply With Quote
Old   December 20, 2017, 02:33
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
As this file is regularly requested, I put it here.
Comments in the file are in french
boucle.zip
m.uzair likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   March 6, 2018, 13:20
yomnag is on a distinguished road
Originally Posted by -mAx- View Post
I send it to you right now
mAx, can I also have a copy of the file? hope you still have it, this is a very old thread. Please send to yomnagobran@yahoo.com Thanks!
yomnag is offline   Reply With Quote
Old   March 6, 2018, 17:18
Muhammad Ali Uzair
dear,
its attached in the comment by the name of boucle.zip :-)
Old   June 12, 2018, 00:36
anonymous
chris_aut is on a distinguished road
Hi
can anyone tell me the solution or how I can do a do-loop, for-loop or while-loop in a journal file in fluent
that's actually what the thread should answer, but all answers are for a scheme file. The title is about a journal file
Please help me
thanks
PS: wouldn't it be easier for all to post a code instead of sending an email? If someone wants to know something and the old users do not answer the information is lost
chris_aut is offline   Reply With Quote
Old   June 12, 2018, 06:19
Ehsan Asgari
syavash is on a distinguished road
Originally Posted by chris_aut View Post
Hi
Please help me
thanks
See the thread below:
Journal for fluent: Scheme programming
Regards,
Syavash
syavash is offline   Reply With Quote
Old   June 12, 2018, 06:36
anonymous
Regards,
Syavash
Hi Syavash
that's exactly what I'm NOT looking for.
I need a loop I can directly use in journal WITHOUT the useage of a scheme-file.
For better unterstanding it should look like the following:
for(x=0;x<10;x++)
solve iterate 1000
file write-case-data name"x".cas
so the name of the file should also change by the value of x
Chris
Old   June 12, 2018, 07:50
Ehsan Asgari
Hi Syavash
for(x=0;x<10;x++)
solve iterate 1000
Chris
I really don't get what you mean! You can write the loop above in a file using Scheme language and simply load it into Fluent using Read-->Journal...
You can have variable file name in that loop, for instance:
(Ti-menu-load-string (format #f "file/write-case-data Base2-AOA-~a.cas" x))
Regards,
Syavash
Old   January 17, 2019, 06:24
haider ali
haider11 is on a distinguished road
hi. could you send me that file to haider7771@hotmail.com.
thanks
haider11 is offline   Reply With Quote
do loop in Fluent journal file. caterchen FLUENT 12 November 14, 2016 23:57
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 18:33
