Controlling surface transparency via command line
Old   April 18, 2006, 14:30
Default Controlling surface transparency via command line
SBottenheim
Hi
I am trying to find out how to control the transparency of surfaces using the command line. So far, I have been unable to find the path required to get to this.
I know that this can be done manually by the scene menu, however I would like to know how to do this by the command line.
Any help on this would be great!
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
