Problem with temperature contour.
Old   April 18, 2006, 13:14
Default Problem with temperature contour.
Ouss
I am modeling the heat transfer between a laptop and its environment in a closed room. The temperature diagramm shows me a reversed temperature : the laptop is colder than the environment! I tried both negative and positive values for the the heat generation rate but it seems not to resolve the problem. I would really appreciate any help or advise. Thanks.
Old   April 18, 2006, 18:04
Default Re: Problem with temperature contour.
freeman
the only advice is TRIPLE check that you set the problem right in fluent. do your heat balance correctly and try to change the values to see if there's different in results especially the sign. lastly, remember that fluent works in Kelvin(K) and all Tspec has to be in K, if you're using SI. I'm not metric fun so I can't comment on that. good luck
TEMPERATURE LIMITED problem emanuele FLUENT 9 June 15, 2018 11:45
PorousMedia Problem with Temperature Distribution pawan OpenFOAM Running, Solving & CFD 2 August 3, 2015 00:08
Problem with transport properties depending on Temperature galaad OpenFOAM Running, Solving & CFD 5 December 6, 2005 13:51
display filled contour of temperature gradient Frederik FLUENT 4 August 23, 2005 06:42
Tecplot problem of plotting boundary in contour mafoi Tecplot 1 April 5, 2005 07:43
