Obtaining Reynolds Number in FLUENT
Old   April 18, 2006, 01:36
Default Obtaining Reynolds Number in FLUENT
Emmanuel
Given Mach number (Fixed), angle of attack, chord length (1m), Reynolds number, I have modeled the flow of air around an airfoil using the Spalart-Allmaras model. I used the FLUENT tutorial, there is no way to input the Reynolds Number directly. How do I obtain the Reynolds number, and how do I vary the Reynolds number? I know Re = (U*L*rho)/mu, I used farfeild in the "Compute From" of the Reference Values. Should I just substitute with the numbers given there to obtain Reynolds Number?
Old   April 21, 2006, 18:53
Default Re: Obtaining Reynolds Number in FLUENT
Gurkan
As you have written, you can change the density and/or viscosity. (If Mach no was not a concern, you could change the velocity and could still work with air)
greetings.
Old   April 7, 2016, 02:46
Default Mach number
Amit soni
Amit soni is on a distinguished road
But U is not matching when i calculated with M and Re
Amit soni is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
Reynolds Number and Heat transfer Coefficient panos_metal FLUENT 0 January 7, 2011 07:37
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
What is "Resolved Reynolds Stress" for LES model in Fluent? ivanbuz FLUENT 0 November 1, 2009 17:36
Fluent 6.4 courant number Aris Nikolopoulos FLUENT 0 May 6, 2008 09:52
