HELP! Diverging Solution for Incompressible Prob.
Old   April 16, 2006, 02:58
Default HELP! Diverging Solution for Incompressible Prob.
Bob
Please help! I am trying to finish up this project so that I can graduate in June! I am modeling half an aircraft at incompressible flight speeds and have tried to get the Spalart-Allmaras model to work for higher angle of attack cases, but my solution diverges after 9-10 iterations each time. I have ran an inviscid solution on the same grid and got a converged solution after a little more than 400 iterations that seemed reasonable. I have a feeling that it may be caused by some highly skewed cells present in the mesh. Is this correct? I have tried to minimize the number of highly skewed cells as much as possible, but can't seem to completely get rid of them. Would anyone be willing to look at my mesh in GAMBIT and give me advise? I would greatly appreciate it. I unfortunately do not have access to TGrid. Please email me for more details on the problem and things that I have tried. Thank you so much for any help!!!
Old   April 16, 2006, 14:44
Default Re: HELP! Diverging Solution for Incompressible Pr
Joe
Use size functions throughout your domain and also resolve the boundary layer with hex/quad (not tri) elements.
Old   April 16, 2006, 16:44
Bob
I'm using a curvature size function for the aircraft body surfaces and a meshed size function for the flow volume with the aircraft faces as sources. I fixed the skewness problem early this morning (found a ver small sliver that contained a bunch of skewed elements), so hopefully that will help. Any suggestions on using GAMBIT for the boundary layer versus adapting the grid in FLUENT? Any advice for either approach? Thank you!!
Old   April 16, 2006, 20:33
Joe
If using a fixed BL, do not exceed an aspect ratio of 1 : 1.2.
Integrated conjugate heat transfer solver in OpenFOAM hjasak OpenFOAM Running, Solving & CFD 172 April 13, 2023 01:42
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 22:22
Solution converged, and then diverge again. jrg FLUENT 2 April 2, 2013 00:10
Mesh independent solution CFX Begineer CFX 0 October 27, 2002 11:54
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
