Velocity LES UDF
Old   April 15, 2006, 08:32
Default Velocity LES UDF
Lourival
Hy every one... I'm trying to make an UDF that can export in a TXT file some information about my velocity field computed using LES. But I can't find how can I acess thouse information via UDF. Some of them are:
1) subgrid-scale turbulent viscosity 2) mixing length for subgrid scales 3) Smagorinsky constant using the Dynamic model or not 4) kinetic energy at small subgrid scales
Does some one ever did something like this???
Thanks a lot
Lourival
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 14:58
UDF for velocity dependant of time GOVIP Fluent UDF and Scheme Programming 3 August 29, 2011 03:27
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
subgrid turbulent viscosity for UDF in LES David TAIEB FLUENT 0 April 2, 2007 09:27
Urgent! Help on UDF to set inlet velocity Ray Hong FLUENT 4 December 30, 2005 13:32
