Heat transfer coefficient - what is waht
Like Tree2Likes
Old   March 11, 2014, 11:42
François Grégoire
macfly is on a distinguished road
Originally Posted by FLUENT CFD View Post
Hi
What do you mean the Bulk Temp.?? is it inlet fluid temp??
thanks
http://lmgtfy.com/?q=fluid+bulk+temperature
macfly is offline   Reply With Quote
Old   July 10, 2017, 13:08
AnsysUser
Shreman is on a distinguished road
Originally Posted by cdf_user View Post
The h values reported by the fluent are wrong. It has something to do with the reference temperature which can be different for different models. Ask fluent engineer. To get the right h value you need to write a udf.
h = heat_flux / (T(z) - Tbulk(z))
Tbulk = SUM mu*cp*rho*Tf dA / SUM mu*cp*dA
Could you tell me where did you get this formula from because for the Tbulk dimesions don´t match on both side..
Shreman is offline   Reply With Quote
Old   August 14, 2017, 05:09
Taiwan,new north city
Rajaero is on a distinguished road
hello guys,
i am also doing the forced convection problem between the solid body and fluid domain. i have read all of your comments and i followed all of it. so my question is that after i changes the reference temperature in fluent i got some h value. but i wanna make sure whether that h value is correct or not.
if somebody explain, how to write a UDF for calculating the exact h value.
Thanks in advance.
Rajaero is offline   Reply With Quote
Old   August 20, 2018, 07:41
Default about udf.
  #24
sujal
sb16 is on a distinguished road
can you please elaborate on how and where to write udf.?
sb16 is offline   Reply With Quote
Old   August 31, 2020, 07:41
Sai Krishna
Sai Krishna is on a distinguished road
Hi
thanks
no its the average temperature of inlet and outlet for an internal flow. its not physically correct to take one temperature (inlet) to estimate the fluid properties, as fluid temperature is continuously changing from inlet to outlet because of heat transfer. hence,if u want to calculate what would be the heat transfer and coefficients usually we will take average of inlet and outlet temperatures.
Regards
Sai Krishna is offline   Reply With Quote
Old   December 21, 2021, 07:14
physics baali
somia baali is on a distinguished road
Originally Posted by Chandra Murthy
;131254
Fluent directly calculates heat flux on the boundaries. In Fluent, heat transfer coefficient (h) is a derived quantity using reference temperature, adjacent fluid temperature and heat flux. In the actual scenario, the reference temperature should be the wall temperature. Therefore, the values reported by fluent will be an indicative values. To get the actual h values you need to write a UDF according to your need.
what is wall temperature? and how can i determined?please
somia baali is offline   Reply With Quote
Old   December 21, 2021, 14:43
Lucky
This entire thread is whack.
The bulk temperature is the mixed temperature at each location. It is not the average of the inlet and outlet. It is the temperature the flow would have if you magically somehow mixed all of it together. The inlet has an inlet bulk temperature. The outlet has an outlet bulk temperature. Everywhere, has a bulk temperature.
For internal heat transfer, the bulk temperature is commonly used as the reference temperature for the heat transfer coefficient but also for all the fluid properties. Some people are too lazy, or they just don't have the skill to calculate the bulk temperature and they will use the average of the inlet and outlet instead as a very crude approximation.
The wall temperature should not be used for the reference temperature, that would just make the heat transfer coefficient undefined because htc=q"/0.
Wall temperature you get from Fluent.
somia baali likes this.
Old   December 29, 2021, 08:13
physics baali
thank you a lot about the answer, but how can i found wall temperature from fluent
Old   December 29, 2021, 17:29
Lucky
There is a variable literally labeled wall temperature in Fluent. Just plot it.
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
Question on heat transfer coefficient!!! Benny FLUENT 7 June 7, 2005 10:25
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
