ANSYS file into Fluent
Old   April 12, 2006, 01:52
Default ANSYS file into Fluent
Liaquat
Hello I have seen an option in the File Import in Fluent where it says ANSYS but when selected, does not read a typical .db or .dbb file from ANSYS. When clicked on File Type in the bottom of files select window, it says ANSYS Prep 7 files. Any idea on what file extension is Fluent looking for from ANSYS. Thanks
Old   April 12, 2006, 04:15
Default Re: ANSYS file into Fluent
philipov
See Export instructions in ANSYS. I think you waht to use the mesh from ANSYS into FLUENT.Then export the model into a suitable format.
Old   April 14, 2006, 09:38
Chandra Murthy
Between ansys and fluent, data can be imported/exported with *.cdb format only.
Old   April 16, 2006, 14:09
Liaquat
Hello Chandra Thanks a lot for the hint. however, there is no extension option as .cdb in Ansys. When I type this extension myself, ANSYS does save the file as cdb and Fluent tries to open it also but then five error such as bad format. Would you pl guide me exactly through the sequesnce in Ansys and Fluent. Thanks
Old   April 17, 2006, 11:32
Chandra Murthy
you can use CDWRITE/CDREAD command in ansys to write/read *.cdb file. Refer ansys help for these commands.
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
Import Fluent file to ansys v_h_memar FLUENT 0 December 14, 2009 01:16
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 12:47
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 07:43
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
