jet of mixture
Old   April 10, 2006, 18:22
Default jet of mixture
Mazyar
Hello.
Thanks for interest in reading this question. I have a simple 2D Jet. The jet is a mixture of 99% air and 1% CO2. The jet spreads within an infinite domain like a large room. So the main domain of the problem is a rectangular zone with a jet as an inlet. I use multi-phase model, either MIXTURE model or Eulerian. The streamlines seem to be correct, however there is almost no CO2 flow at two sides boundaries. All these boundaries are Pressure-Outlet, except the jet exit which is Velocity-Inlet. If you have experience in this area, could you tell me whether modeling a mixture of gas-gas using Multiphase models is appropriate or not? If we can use it in this case, do have any idea why the concentration (volume fraction) of the CO2 is weired? If you are interested I can send you a sketch of the problem and the contours of the cocentrations.
Thanks, Mazyar
Old   April 11, 2006, 03:07
Default Re: jet of mixture
Rags
I think you need not to use multiphase model. Only using multispecies model will do. Please set up ur problem again with multispicies model. and then let me know the results
2D Plane Jet Fluent Solution doug Main CFD Forum 11 February 4, 2019 10:34
mixture mass continuity eqn v.s. volumetric mixture continuity eqn kaifu ANSYS 0 June 9, 2011 09:42
mixture mass continuity v.s. volumetric mixture continuity in pressure equation kaifu OpenFOAM 0 June 9, 2011 09:14
Atomization of Liquid Jet using Mixture Mutiphasemodel ajayanthi42 FLUENT 0 February 10, 2011 19:16
Improvement to the update of T_ et al in hMixtureThermoC and hhuMixtureThermoC richpaj OpenFOAM Bugs 2 October 9, 2008 23:14
