April 10, 2006, 13:29 |
GAMBIT Error: Cannot open connect stream
I am having problems with Gambit, as it does not want to start. I installed exceed and Gambit (dowloaded from the Fluent user service centre), but I get this error message when I try to load Gambit: "Cannot open connect stream TRANS(SocketINETGetAddr): tnamebysocket()failed TRANS(SocketINETConnect): TRANS(SocketINETGetAddr) () failed TRANS(Open): transport failed for tcp/DLGFNTK0J:0 Unable to open display" Does anyone understand what that means? |
April 10, 2006, 13:40 |
Re: GAMBIT Error: Cannot open connect stream
Yes, Your support engineer does |
April 11, 2006, 10:17 |
try disabling any firewall or antivirus on your computer.Some times firewall stops the socket created by exceed for the gambit
khanja |
April 12, 2006, 00:20 |
Hi, To make thing simple, I suggest you uninstall exeed and mabit. and then re-install them by the order: exceed and gambit. Maybe, it is ok.
April 12, 2006, 12:58 |
Thank you Jun and Khanjagr for your help.
I didn't have all the administrator rights, so some features were not installed the first time. With the total administrator rights, I re-installed Exceed and now it works just fine! Marion. |
[GAMBIT] Gambit to open and old msh file | Muntasir | ANSYS Meshing & Geometry | 5 | August 2, 2012 03:21 |
[GAMBIT] Gambit & 3d open channel flow mesh problem | esgee | ANSYS Meshing & Geometry | 7 | April 10, 2012 01:51 |
[Commercial meshers] An open source software like gambit | ilpaso | OpenFOAM Meshing & Mesh Conversion | 4 | June 18, 2008 17:32 |
OpenFOAM with IBM AIX | matthias | OpenFOAM Installation | 20 | March 25, 2008 03:36 |
How to open .SAT file by GAMBIT? | Ertan Taskin | Main CFD Forum | 2 | September 25, 2007 09:35 |
