External Incompressible flow Boundary conditions
Old   April 10, 2006, 13:00
Default External Incompressible flow Boundary conditions
Himanshu Almadi
hi I am not able to figure out boundary conditions for a 3d mesh having a body shell of supermileage car that is to be simulated using fluent 6.1 at 34 m/s of air speed. The general velocity inlet and pressure outlet are leading to divergence in viscous models. Please help at the earliest
Warm Regards Himanshu Almadi Delhi College of Engineering
Old   April 11, 2006, 03:12
Default Re: External Incompressible flow Boundary conditio
Rags
Please check if u have scaled the model accurately.Which turbulence model u r using? Also check, turbulence properties at inlet and outlet. I feel that vel inlet and pr out shud work.
Old   November 13, 2009, 10:17
ramin
ramins is on a distinguished road
hi
I want to model an incompressible external flow over a flat plate. whlie I want to set the far-field boundary condition, Fluent gives me a msg that far-field could only be used with ideal gas which is a compressible flow case.
please help me, what should I do to model far-field?
ramins is offline   Reply With Quote
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Help.. Boundary conditions for external flow... suresh1483 Main CFD Forum 5 April 14, 2011 12:26
CFX does not continue Shafiul CFX 10 February 17, 2011 08:57
Boundary Conditions Jan Ramboer Main CFD Forum 11 August 16, 1999 09:59
