Hello everybody! can one tell me how to plot stream function on 3d, with fluent???????? thanks.
Dear sir stream function is defined only for 2D flow. khairy-Egypt
I WANT TO VISUALIZE THE STREAM FUNCTION ON A PLAN (but my configuration is on 3d in fluent)? I CAN'T DO IT!!!!?????? how to do then????????!!!!!
You can use path lines...It's almost the equivalent result for 3D flows,
Arn |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
OpenFoam 14 installation problem | gfcoppola | OpenFOAM Installation | 20 | November 2, 2007 13:38 |
separation and stream function | co2 | FLUENT | 0 | December 27, 2003 18:18 |
HELP - stream function from the velocity field | Fred | Main CFD Forum | 10 | January 26, 1999 12:58 |
Stream function and vorticity for turbulence flow? | Willard Lee | Main CFD Forum | 1 | January 20, 1999 11:03 |
