Problems with multiphase wetsteam model
Old   April 7, 2006, 10:09
Default Problems with multiphase wetsteam model
Guido
I'm tring to make a tesi on the nucleation of water in the last stage of LP turbine. I'm using the wetsteam model present in Fluent 2.16 and I face convergence difficulties while solving wet steam flow, also using first order discretization schemes, lower under-relaxation (0.1). I have many problems expecialy with the "wsb" equation. There is some one can help me? Thank you very much! Guido
Old   April 7, 2006, 10:17
Default Re: Problems with multiphase wetsteam model
Gorno
it is very difficoult that yuo can have good result in convergence with wet steam model.
Old   August 12, 2010, 06:07
Default wet steam model
maryam
salam is on a distinguished road
hello everyone,
I have a real gas contains vapor water as my material that in my model water condensation will occur. please tell me if i can use the "wet steam" model in my simulation. if yes, can I use the srk eos as udf with wet steam model because the pressure in my work is very high.
thanks a lot
salam is offline   Reply With Quote
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
mixture model or multiphase model in my UDF? aleisia Fluent UDF and Scheme Programming 0 June 8, 2011 14:25
air and water vapour mixture - multiphase model Saba FLUENT 0 February 10, 2009 13:05
multiphase cfd model problems zhijing peng FLUENT 0 January 7, 2009 14:07
Convergence/results problems in a model Isaac Phoenics 0 April 18, 2007 04:05
