April 3, 2006, 03:23 |
About Gambit and Parallel Computing
Hi everybody. I have some question about Gambit and Fluent.
1. I want to mesh in Gambit but it spend many time. Does Gambit has parallel mesh generation ?? or There are another program can use parallel mesh generation and can import to Fluent 6.2?? 2. I define source term by UDF. I can not run this code in parallel version. Do you have any suggestion for me?? Best regards, Yuki |
September 6, 2009, 11:13 |
Sayros yadgar
Rep Power: 17 |
Did you find out how to run gambit in parallel mode? is it possible to do that?
Thanks, |
September 7, 2009, 02:13 |
Maxime Perelli
Rep Power: 41 |
I don't think so
The best way should be to run gambit under linux 64 bit
In memory of my friend Hervé: CFD engineer & freerider |
GAMBIT on Parallel | Aeor | FLUENT | 2 | November 12, 2007 19:47 |
Does gambit has parallel mesh ??? | yuki | FLUENT | 0 | January 12, 2006 02:36 |
parallel computing and batch | ahmet | FLUENT | 0 | December 20, 2005 15:11 |
Gambit can be run in parallel? | zjuADou | FLUENT | 1 | July 24, 2005 08:33 |
Gambit in parallel | galeazzo | FLUENT | 3 | April 12, 2005 17:47 |
