MOVING WALL
Old   April 1, 2006, 17:28
Default MOVING WALL
Michele
Hi all! I'd like to model a moving wall in the perpendicular direction to the main flow stream.
Do you know if is this possible?
In this case do you know how can i manage it?
Thanks
Michele
Old   April 2, 2006, 17:36
Default Re: MOVING WALL
Luca
Unfortuantely you just need to use the dynami mesh. It's not possible to set a velocity field perpendicular to the wall in Fluent (up to now!). So forget the traspiration method. Luca
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh Shoonya OpenFOAM Meshing & Mesh Conversion 11 January 20, 2012 07:23
How to make boundary layer mesh moving with wall wayne FLUENT 3 June 12, 2008 00:23
moving wall... kekko CFX 0 February 2, 2007 14:11
moving wall and fluid soody FLUENT 3 September 20, 2004 02:37
moving wall Steff FLUENT 0 February 7, 2002 05:49
