March 24, 2006, 05:32 |
Propagate Algorithms
Hello, I'm trying to simulate a supersonic shell at Mach 2.4 (7.62mm, 20mm, 30mm, etc shells) and its sonic boom, 1 meter away (1 meter for the tests but it should be 8 meters minimum !!).
I've heard that the best method wasn't to simulate from the near to the far field directly but to procede in 2 steps (or 2 zones) consisting of the near field CFD solution and a propagation to the ground (from the near to the far field). Does any body knows if this can be done with fluent ? (and where does end the near field...) Thanks ! Cyril |
CFD Lecture Course Numerical Solution Algorithms for Compressible Flows | hjasak | OpenFOAM | 2 | March 8, 2017 15:30 |
Algorithms (McGraw 2006) Please help | itoa | FLUENT | 4 | June 11, 2009 01:10 |
Why SIMPLE family algorithms are not used in LES? | Linfeng BI | Main CFD Forum | 5 | November 19, 2002 20:05 |
AI Algorithms? | Radu Bondar | Main CFD Forum | 0 | October 7, 2002 19:13 |
steady k-eps algorithms | Bengham | Main CFD Forum | 0 | February 5, 2002 10:34 |
