Fluent simulation-hardly any arrows!
Old   March 24, 2006, 03:40
Default Fluent simulation-hardly any arrows!
Neha
Does anyone know why sometimes we get hardly any velocity vectors after the iterations? I used viscous/laminar flow, material/water, 0.01 m/s flow, 1000 iterations, and got just some blue dots by way of velocity vectors!can anyone tell me why?
Old   March 24, 2006, 04:42
Default Re: Fluent simulation-hardly any arrows!
Ahmed
Have you tried to increase the scale of drawing the arrows?
Old   March 24, 2006, 15:47
Neha
i did try that...and that helps a little, but it doesn't take away from the fact that there is something wrong...coz all the arrows tend to be the same color.. on other occasions, similar simulations gave me proper, mulitcolored, thousands of tiny arrows, that make the picture 'look right'. ..but sometimes..all i get is some scattered blue dots..which i have to scale to make it look somewhat normal!
Old   March 24, 2006, 17:44
Ahmed
try to skip no vectors, try other paremeters in the display menu window e.g. auto range, etc. Cheers and good luck
Old   March 25, 2006, 09:27
KP
Click on fluid and then go ahead. kp@dal.ca
3D Simulation of the Plasma Jet in FLUENT Steve FLUENT 9 April 20, 2012 07:42
Combustion SImulation in Fluent santhosh1987 FLUENT 0 May 14, 2010 11:32
IC engine simulation tutorial by FLUENT yash Main CFD Forum 1 April 21, 2009 06:05
Can Fluent start a simulation from a negative time Ted Chu FLUENT 10 November 26, 2008 22:06
Convert existing Star-CD simulation to FLUENT Lam FLUENT 3 June 10, 2003 13:00
