Not getting vortex shedding behind square cylinder
Old   March 23, 2006, 08:27
Default Not getting vortex shedding behind square cylinder
Hari
I am working on flow around square cylinder using Fluent. First I got steady state solution using ske model. Then I switched to Unsteady with time interval 1/20 of expected shedding period. I am not getting periodicity in the contours of vorticity or static pressure. Anybody help me in this regard.
Old   March 25, 2006, 06:52
Default Re: Not getting vortex shedding behind square cyli
Muhammad Shakaib
You can try laminar-unsteady model.
Old   March 27, 2006, 01:57
Hari
Thanks Muhammad
I tried using laminar-unsteady model following the steps given in tutorial for a circular cylinder given in studentfluent.com. But still I am not getting the vortex shedding when I use sk-e(2d) with standard wall functions.
Thanks once again.
Old   March 27, 2006, 05:22
alex marshall
then ask fluent engineer
Old   March 28, 2006, 14:48
Jeffery822
You should make the mesh very fine. It works for me.
Old   March 30, 2006, 02:35
Hari
Thanks Jeffery822,
Initially my mesh included 12000 cells. I tried with 60000 cells now. But after few 100 time steps, the lift coef. converges/stabilises to 0. I feel I might be doing something wrong at basic level. Here are my problem details:
1) b = 0.06m; U = 5.356 m/s with 2% turbulence intensity; Fluid = Air; So Re=22,000 2) problem domain is 21b in streamwise direction and 15b in other direction. 3) Standard k-e model, Standard wall functions with first node from wall being at 0.02b 4) Time step 0.004 s (i.e. (1/20) of shedding period of 0.08 s) 5) Velocity inlet, Pressure outlet and periodic boundary conditions 6) Applied a patch of Y-velocity equal to 1m/s and -1m/s in the top and bottom regions of wake, respectively.
Could please throw some light becasue you mentioned that the problem worked for you.
Thanks once again
Old   April 12, 2006, 06:54
sujay
you will get ...contact me later
Old   April 12, 2006, 09:14
Hari
Thanks Sujay.
I did get the vortex shedding when I reduced the eddy viscosity ratio at velocity inlet boundary.
You can post any further technical information in this regard.
Thanks once again.
Need advices for simulating vortex shedding of moving cylinder quyetthang CFX 0 October 1, 2011 06:39
3D cylinder and Vortex Street shedding issues josik_1982 FLUENT 2 July 17, 2010 11:19
Vortex Shedding & Cd on Cylinder Franciswu21 FLUENT 0 March 20, 2009 13:29
Motion of cylinder due to vortex shedding ACHILLEAS TSOMPANOS FLUENT 3 November 24, 2006 04:06
Vortex shedding for square cylinder zonexo Main CFD Forum 8 March 30, 2006 16:11
