UDF with user created surfaces
Old   March 22, 2006, 13:33
Default UDF with user created surfaces
Henry Lee
I'd like to do surface integration using UDF on some surfaces that I created for postprocessing purpose. It seems UDF can only access those boundary surfaces using Lookup_Thread(domain,surface_thread_id). Does anyone know a way to access the non-boundary surfaces in UDF? Thanks in advance.
Henry
Old   March 22, 2006, 18:37
Default Re: UDF with user created surfaces
RoM
You cant access post processing surfaces in udf. The only way i know is to create the post process surface in gambit an define it as interior. Then you can access it later in your udf.
RoM
Old   March 23, 2006, 04:24
Markus
Hi Henry, Have a look at the UDF-Archive at www.fluentuser.com, the UDF with solution ID 1056 will do the trick if you are working on Linux/Unix. Markus
UDF for 'user defined enthalpy' sak2129 FLUENT 0 December 29, 2010 15:44
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
use of user defined functions (UDF) Vedavyasa M FLUENT 0 June 27, 2007 07:21
parse error- new udf user aks FLUENT 1 June 20, 2007 04:55
DEFINE_DPM_OUTPUT macro UDF HELP Puneet FLUENT 3 November 28, 2003 11:55
