March 20, 2006, 14:48 |
grid adaptation
to satisfy the Y+ range for a turbulent flow over an airfoil, after convergence I adapted the mesh around the airfoil and iterated until the lift and drag reached a constant value. After this the Y+ is within the range. But after adaptation, residuals do not converge anymore. Is the procedure correct? Thank you |
March 23, 2006, 05:33 |
Re: grid adaptation
hi,
what type of adpation did you do... I mean did you adapt by selectiong the region? if so, then you can go for adaption on the basis of y+. after the adaption the residuals will shoot up, but will come down very fastly to the same level that you had. if still problem persists, then adapt the mesh in steps, i.e. adapt the cells with higher y+,let the case run for some time time so that residuals will come to prevoius level, then again for next step with low y+ Prashant |
March 23, 2006, 18:25 |
Re: grid adaptation
Thanks for your help,
After convergence, I did Boundary Adaptation (adding 2 rows of cells) around the airfoil walls. Iterating again, residuals initially decrease very fastly, then reach a constant value, but energy equation residual now is above the limit (1e-6). I'll follow your suggestion creating 1 row of cells, iterating for some time, and then adding another row of cells and iterating again. Thank you very much |
No grid adaptation | Pimmie80 | FLUENT | 1 | September 21, 2010 08:35 |
grid partition AND dynamic mesh adaptation !!!!!!! | bohis | FLUENT | 0 | January 16, 2009 03:00 |
Grid Adaptation | Suresh | FLUENT | 0 | October 15, 2003 13:18 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
floating point error during grid adaptation | Nurul Murad | FLUENT | 2 | September 5, 2001 19:15 |
