mixture or eulerian
Old   March 20, 2006, 01:31
Default mixture or eulerian
van
hi
iam modeling flow through horizontal pipe of 10m length of two immiscible liquids.can anyone suggerst me which model is more suitable mixture or eulerian. i read some papers by angeli she has mentioned about homogeneous model which is mixture model.so will the results differ like pressure gradient if i use eulerian model.
Old   March 20, 2006, 05:55
Default Re: mixture or eulerian
vamsi
Hi
I dont have much knowledge. But mixture model assumes same pressure through out the domain, where as Eulerian model considers different pressures in the two phases. You can go to mixture model if u dont require individual considerations.
mesh size in Eulerian multiphase flow - liquid/solid mixture microfin FLUENT 4 December 23, 2016 14:55
Difference between Mixture & Eulerian multiphase ? Shankar FLUENT 6 October 7, 2015 09:45
Mixture and Eulerian Model Hassid S. FLUENT 1 August 9, 2007 08:24
Tee Channel (Mixture and Eulerian Multiphase Mode) Pathway FLUENT 0 January 23, 2007 03:22
can we use same udf for mixture n eulerian model Rashmi FLUENT 1 March 28, 2006 17:32
