Flow around a cylinder at subcritical regime.
Old   March 18, 2006, 10:18
Default Flow around a cylinder at subcritical regime.
yousef
Hi, i'm trying to model a 2D external incompressible flow about a circular cylinder attached with two plates at the rear separeted by a distance of 0.86 of the cylinder diameter, the plate length equals the cylinder diameter. the Re is 8x10^4 (subcritical regime), and i want to model both an unconfined and a confined flow case. the confined flow case will be for the cylinder placed between two walls, the cylinder diameter is 47mm and the wall spacing is 300mm. can you guide me of what kind of mesh is best for this problem? what wall functions shall i use? which is best for the unconfined & the confined cases, the k-e or the RSM ot LES? what recommendations you suggest? i will highly appreciate your help? my problem is steady and i use Gambit for mesh generation. Any documents or pdf files you have and can support me? thank you alot in advance for your help.
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
flow around a cylinder pXYZ Main CFD Forum 14 July 25, 2011 11:05
flow around circular cylinder...plz help yousef FLUENT 4 March 28, 2006 12:01
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
