VIRTUAL VOLUME
Old   March 16, 2006, 15:41
Default VIRTUAL VOLUME
Sean Cody
What exactly is a virtual volume as opposed to a real volume. I've created more concentrated meshes within my volume and want the faces of the inner volumes to act only as boundaries for the mesh, not as boundaries of flow. Is this the application of virtual volumes?
Sean
Old   March 17, 2006, 03:25
Default Re: VIRTUAL VOLUME
RoM
A real volume can be desrcibed by a mathematical function within a tolerance of 1e-6. Boolean operations will work on real gemoetry, but the possible shapes of of your volume are limited. Virtual gemeometry (volumes,faces,lines) does not have this limitation, but you should be aware that most of gamibts boolean operations do not work with virtual geometry. Changing real geometry into virtual is usually done short before meshing to simplify the geometry which often makes meshing easier.
RoM
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
