3d Airfoil Modelling Problems
Old   March 16, 2006, 07:54
Default 3d Airfoil Modelling Problems
Olly
Hi
I'm trying to model a 3d airfoil using fluent but am having problems getting the solution to converge. The times that it has converged there is a negative gauge pressure everywhere except for a small point at the front of the wing.
I've modelled the wing in a wing tunnel with the following boundary conditions: Inlet - Velocity inlet set to 40ms Outlet - Outflow All other walls set as Symmetry
I'm using the k-epsilon solver, i've tried changing the mesh a few times from coarse to fine but am having no luck an ideas?
Thanks
Old   March 16, 2006, 09:50
Default Re: 3d Airfoil Modelling Problems
Oleksiy Dushyn
- you should replace your symmetry doundary conditions by periodic ones;
- if you are simulating a static case do not make your mesh too fine otherwise you'll run to another problem with flow stability;
regards,
Alexey
Old   March 17, 2006, 10:53
Olly
Thanks for the reply,
I changed the outflow to an outlet pressure and this seems to solve the negative gauge pressure up and down stream of the airfoil.
I'm now having problems trying to get it to converge at all. the residual plots just go up and then it doesn't converge, what does this mean?
Thanks
Old   March 17, 2006, 11:44
Oleksiy Dushyn
As I've wtitten in my last posting if you want to get a good convergence you have to replace your symmetry BC by periodic ones.
Good luck
Old   March 17, 2006, 12:12
Olly
Thanks again, i have replaced the symmetry bc with periodic ones but with no success.
What would cause the residuals to go up?
Thanks
Old   March 17, 2006, 13:55
Oleksiy Dushyn
What initialization do you use?
Old   March 17, 2006, 15:26
Olly
I initalise it from the inlet, is that what you mean?
Old   March 19, 2006, 16:10
Riaan
1) use fmg-initialization
2) reduce your under-relaxation functions
3) does your mesh "CHECK" ok?
Calculating polars from 2D airfoil coordinates... wlvrn Main CFD Forum 0 August 18, 2010 19:43
Help needed with Cornell's Gambit airfoil tutorial AW FLUENT 6 February 26, 2010 23:42
Multi-Body Airfoil simulation problems ivan_cozza OpenFOAM Running, Solving & CFD 2 September 17, 2009 06:38
Modeling Backflow for a 3D Airfoil (Wing of Finite Span) Josh CFX 9 August 18, 2009 12:31
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 19:36
