Run Fluent on a 64 bit machine
Old   March 16, 2006, 05:58
Default Run Fluent on a 64 bit machine
Fluentuser
Hi Guys! we're waiting for our new 64 bit machine to arrive. Up to now we've used only 32 bit machines. Do we need a specific 64-bit release of Fluent or we can simply install what we have. Thanks for your attention.
Old   March 16, 2006, 06:56
Default Re: Run Fluent on a 64 bit machine
ulwa
You can (may not be true for all OS's) install the 32-bit version on a 64-bit machine but then your new machine will run in "32-bit mode". If it is a Window-box you have no choice, since there is no 64-bit windows-version of Fluent yet.
Old   March 16, 2006, 07:07
Fluentuser
I use Linux..ok thank you for your advice.
Old   March 16, 2006, 07:18
grisu
As already mentioned, you can use the 32bit version, but it will be approx. 25% slower than the 64bit code.
Old   March 16, 2006, 09:54
Oleksiy Dushyn
This moment I'm running Fluent on 64bit AMD Dual-Core CPU workstation. My suggestions are:
- you should use 64 bit version of Fluent; - you should use 64 bit version of Linux. - RedHat, Suse, Fedora do not work with Fluent; - the best results I've got were with new Mandriva Linux.
Old   March 16, 2006, 10:01
grisu
We tested all 3 of them - experienced no problems, Fluent runs well! (at the moment we are using Debian)
Old   March 16, 2006, 10:19
Oleksiy Dushyn
I have mentioned what CPU's I'm using. Please, check if you have exactly the same CPU.
Old   March 16, 2006, 10:31
grisu
Yes, it's an AMD64 X2 4200 (dual core).
Old   March 16, 2006, 21:15
onlooker
I'll second that.
Old   March 17, 2006, 08:43
chem
wait wait So is ther a 64 bit Fluent?? I `ve heard that version 6.3 will be a 64bit but ...let say Fluent 6.2.16 is 32 bit. Am I right?? Win XP 64 bit (that`s what i am using ) will allow you to extand your RAM memory to 4 GB. Under 32bit u can use 2GB.
Old   March 17, 2006, 11:18
  #11
grisu
There _will_ be a 64bit _windows_ version; but the 64bit linux version already exists for 6.2.16.
Fluent file's 64 bit don't run on 32 bit francescounipi FLUENT 0 February 8, 2010 14:55
Linux64 bit for Fluent 6.2 and Core 2 Quad Jerzy Krawczyk FLUENT 5 April 23, 2007 17:38
To run FLUENT in a 64 bit machine Rucy FLUENT 1 July 4, 2005 09:31
To run FLUENT in a 64 bit machine Rucy FLUENT 1 June 25, 2005 15:17
FLUENT parallel run Sampath FLUENT 6 November 24, 2004 10:52
