pressure drop
Old   March 15, 2006, 06:49
Default pressure drop
siddiqui
hi
i want to find the pressure drop across different length of the pipe.but in the pressure option for contours we dont have any pressure drop.i have not set any periodic BC in my geometry.is thr anyother way of calculating pressure drop.
Old   March 15, 2006, 07:13
Default Re: pressure drop
mAx
hi, you have to create sections in Fluent (sweep Face) Then for computing pressure drop, you must go to report/surface integrals choose Pressure (total pressure) and area weighted average chosse your inlet then compute do the same with the section you created. The drop pressure is the difference between the inlet-value and your section-value hope it helps
guillermo
What I usually do is to calculate the surface integral of pressure in two different planes, so you can calculate the drop pressure by using the difference
Report\surface integrals
pressure drop in the pipe mike.mm FLUENT 6 February 7, 2011 11:31
Pipe Flow - Pressure Drop Daniel L FLOW-3D 2 December 10, 2010 05:23
Total and static pressure drop Janakiram Siemens 1 February 8, 2009 02:32
Pressure Drop at entrance of a rotor-stator. Resnick Main CFD Forum 0 November 20, 2007 15:50
Periodic boundaries and pressure drop MatejK CFX 2 July 12, 2005 05:47
