residuals oscillation
Old   March 13, 2006, 13:57
Default residuals oscillation
nick
modeling turbulent flows, what can I do if residuals oscillate about a constat value far from convergence?
Thanks
Old   March 13, 2006, 14:21
Default Re: residuals oscillation
mAx
switch on unsteady solver
Old   March 13, 2006, 19:40
Matt
Im modelling turbulent flow with the k-e model. So far ive been using the steady flow solver.
Turbulent flow is always changing with time, so should you use an Unsteady solver for ALL turbulent flow modelling?
Matt
Old   March 14, 2006, 06:13
edi
If you're modeling external flows (flow around buildings, cars, airplanes), consider to extend your domain past the obstacles until the flow is fully developed. This hint can be applied also to internal flows, anyway...
Obviously, all remains valid if there are not other concerns, for example if there are not highly time dependant phenomena (vortexing) and you are forcing a steady solution...
Hope this helps
Edi.
[Tutorials] Tutorial of how to plot residuals ! wolle1982 OpenFOAM Community Contributions 172 December 6, 2024 07:20
what to monitor besides residuals? franzdrs FLUENT 5 March 21, 2013 04:59
Mesh size and solver residuals... Scott CFX 5 December 15, 2008 18:10
Oscillation of residuals in DPM (Ergent need!) yooceframandi FLUENT 1 February 28, 2006 07:46
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 06:45
