VAWT Wind Turbine
Old   March 7, 2006, 11:24
Default VAWT Wind Turbine
Tom Smith
For my Thesis I am modelling a small scale Verictal Axis Wind Turbine in 2D. The turbine has three blades of chord length 0.2m and has a diameter of 2.5m. I am modelling all three blades rotating at 150rpm inside a larger zone using Fluents sliding mesh capability.
I have had a first attempt at solving the model using a relitively coarse mesh. To begin with I solved the flow field in steady-state specifying the rotor as a moving reference frame. I then enebled time dependence and sliding rotor motion using the previous solution as an initial guess for the transient prediction of the flow.
The model now seems to be working. The next stage is to extract performance data. I have tried reporting the torque on the airfoils around the axis of rotation (z-axis), but the torque values are very small and in the wrong direction.
Does anyone have any ideas why my torque values aren't realistic, or comments on my model in general?
Thanks for your help, Tom Smith
Old   April 13, 2009, 15:26
nazareno mancinelli
yochule is on a distinguished road
hi tom. i hope you are still here.
i am modeling a rotor/stator for a hairdrier. and i am asking about the boundary conditions. how do you do set up the boundary? in your case the rpm of the rotor is funtion of the velocity in the far field. in my case the flow rate (or the velocity) is in funtion of the torque or the rpm of the motor. how can i set up the problem?
regards
yochule is offline   Reply With Quote
Old   April 14, 2009, 23:56
panda is on a distinguished road
The torque value is quite dependent on your design and it may be negative or small for a poor design so you need change your design a bit.
panda is offline   Reply With Quote
Old   April 16, 2009, 16:04
salman
salman18q is on a distinguished road
Hey tom...have you had any success yet. I am doing a similar project in 3d.
salman18q is offline   Reply With Quote
Old   April 16, 2009, 17:50
mark
redlemon is on a distinguished road
Ensure axis is correct for reporting and model is scaled
redlemon is offline   Reply With Quote
Old   May 17, 2009, 10:58
bima
bima_ap is on a distinguished road
hello tom, my name's bima. I'm new member in this forum. i join this forum because I have the same problem with you. i want to simulate 3 blades airfoil of VAWT and I use sliding mesh too. please help me if you get any solution.
thanx,
bima_ap is offline   Reply With Quote
Old   May 18, 2009, 11:59
Thanh Nha Nguyen
sime is on a distinguished road
Hi, tom!
I'm trying to simulate a VAWT as u, but i'm using Turbo Mode in Ansys/CFX. Can we exchange some imformation?
Thanks!
sime is offline   Reply With Quote
Old   August 1, 2009, 03:13
faddy ardian
diffy is on a distinguished road
hi tom,,,
i'm doing the same thing as u did for my thesis,,but the turbine is used in water,,I just got the same problem as u,,,the torque values aren't realistic,,,
please help me,,,,
thanks
diffy is offline   Reply With Quote
Old   August 15, 2009, 11:51
Default vwat
nassim swlyman
eng.nassim is on a distinguished road
hi i'm working on VWAT simulation 4 my master now i have begin to try my first mesh using moving mesh to simulate the rotation,s-a 4trublance, unsteady, later i'll try to work on 3d
case. do any one have any case file just to compare with mine
thanks
eng.nassim is offline   Reply With Quote
Old   March 16, 2010, 17:40
benoit paillard
bennn is on a distinguished road
Originally Posted by Tom Smith
;129886
I'm carrying out the same kind of project. My approach was to extract the lift and drag force, project them on tangential and normal vector, and then extract torque from the force projected on tangential axis. results are quite good compared with experiment (20% max error with fully stalled airfoil)
bennn is offline   Reply With Quote
Old   April 1, 2010, 03:30
SHIVA
skshivas is on a distinguished road
Dear Tom.
Hope now u solve the Problem.
i need u r help for same case.
With Regards
SIVA
skshivas is offline   Reply With Quote
Old   August 27, 2011, 02:38
Default Hi
  #12
s.rasoul_varedi
desert_1250 is an unknown quantity at this point
Send a message via Yahoo to desert_1250
i decide to simulate it in 3d Geometry. so i create the 3d geometry and Mesh in Gambit and import it to OF, every thing is ok and i stop the run after 50 rotation degrees. when i see contours of velocity or pressure, every things is ok, but when i extract the mummentum, the result is very bad!!!??? why this happen???
for calculate the forces and mummentum for every blade i added this code in controlDict file :
forces_1
type forces;
functionObjectLibs ("libforces.so");
outputControl timeStep;
outputInterval 100;
patches (Blade1);
PName p;
Uname U;
log true;
rhoInf 1.2;
CofR (0 0 0);
can every one tell me what is the mistaken??
______
Rasoul
desert_1250 is offline   Reply With Quote
High torque coefficient Cm for Vertical Axis Wind Turbine (VAWT) tony00 FLUENT 11 July 23, 2018 07:13
Wind Turbine - Rotation of the Baldes moonomid CFX 32 March 18, 2016 20:34
Torque calculation of 2D VAWT Wind Turbine Anonymized_JL1 FLUENT 14 September 26, 2013 04:35
Ducted wind turbine (BC for the shroud) Pepita CFX 4 June 29, 2013 08:09
FSI - Wind Turbine AUN CFX 13 August 29, 2012 17:44
