Reg "DPM-particle aborted"
Old   March 7, 2006, 05:06
Default Reg "DPM-particle aborted"
GANESH
hai,
Iam working on DPM problem.In that i define my injection as surface injection with a particle size of 50 microns .After the particle DPM iteration i see in the summary report that all my particles are aborted.But if the same injection done with a 1 micron particle , all the particles that are tracked are escaping.Can i know why is this discrepancy. NOTE: Turbulent Dispersion No of tries -0.1,Time scale constant -0.15),Tracking parameter (1e+08),Step length factor -15.
Thanking you,
Ganesh kumar.V
Old   March 7, 2006, 05:27
Default Re: Reg "DPM-particle aborted"
satish
check the wall condition from where u r injecting keep it reflect and tracking parameter 10000 step length 5
Old   March 7, 2006, 06:09
GANESH
hai, thanku for ur kind reply, I had mentioned it as a surface injection,ie(from my gas inlet) & B.C's at all walls reflect only. And this is a cyclone calciner,so i gave a high step length of 1e+08 so all particle will escape.
Thanku GKV
Old   March 7, 2006, 10:45
sreenivas
hi
as far as my knowledge is concerned u"ve to give no of tries in terms of 1,2 3, etc u"ll get more information abt no of tries in fluent user guide .one more thing ur max number of steps will be the product of ur cell elements and step length factor.Make sure ur boundary conditions are (DPM)correct.
hope it "ll works
DPM particle time step amos FLUENT 1 January 4, 2020 09:46
DPM particle tracking in stirred tank parisa- FLUENT 1 August 7, 2012 13:03
DPM particle tracking parisa- Main CFD Forum 2 June 15, 2011 06:12
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
Reg :Particle trajectory report. GANESH FLUENT 0 March 23, 2006 04:11
