Particle Material for DPM
Old   March 6, 2006, 08:30
Default Particle Material for DPM
Stanislav Kraev
How can I define / use my own material for particles in my DPM case? I use FLUENT6.1.22 and wonder if there is no possibility to define particle with specified parameters (such as density, conductivity, etc).
Thanks.
Old   March 7, 2006, 03:06
Default Re: Particle Material for DPM
jiangxuxu
In my opinion, you can choose one kind of material at random.Then in the panel of FLUENT/DIFINE/MATERIALS/PROPERTIES ,you can write your specified parameters instead.
regards.
jiangxuxu
Old   March 7, 2006, 04:11
RoM
You will have to create an injection first, then the material for this injection will appear in the define->materials panel. You can choose it under "material type".
RoM
Old   March 7, 2006, 04:19
Stanislav Kraev
Thanks a lot!
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Adding New Particle Material ali hemmati FLUENT 1 September 19, 2011 15:56
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
How to set particle material in DPM panel romans FLUENT 8 June 4, 2008 21:49
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
