Can I use different turbulence model in dif zones?
Old   March 5, 2006, 22:20
Default Can I use different turbulence model in dif zones?
Andy Cong
Dears,
I have seperate the 3D model in two zones, and I want to use different turbulence models in the two zones.
Can I do this in Fluent? Or I have some mistaken idea?
Thanks.
Old   March 6, 2006, 01:40
Default Re: Can I use different turbulence model in dif zo
thomas
no the idea is good cause some development is made right now at fluent and other to do for example: RANS in the far field and LES close to area of interest (flow around a body for example). Th problem, is what do you use at the interface of the 2 area. If you are an expert both in Fluent and Turbulence devlpment you can do it ... good luck !
Old   March 6, 2006, 02:33
Andy Cong
Thank you for your reply.
I am not very familar with both Fluent and turbulence, so do you mean that this is too difficult for me?
Thanks again.
Old   March 6, 2006, 04:40
Ralf Schmidt
you may separate your domain in two simulations, one far field with one turb. model, and a close field with another turb. model.
Then do a steady calculation for the first simulation, and take the results at the bondary to the second simulation as starting conditions.
Problem: How to calculate turb. input parameters for the second from the results of the first simulation??? Depends on turb. models... No Idea...
Hope it helps
Ralf
Old   March 6, 2006, 05:03
Andy Cong
Thanks, Good idea, My thought is zone A -> zone B ->zone A. But the A-B boundary condition and B-A are difficult to define.
It may be just an idea.
Old   March 6, 2006, 13:11
Evan Rosenbaum
I would swear that FLUENT has a UDF to do this in the user's sections of their website. Now I find it again. I'm not sure it is what you want, but: http://www.fluentusers.com/udf_archi...ples/UDF51.htm
Old   March 6, 2006, 20:45
Andy Cong
I can not link it, Can you send it by Email?
Thanks.
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 08:18
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 14:57
question about turbulence model selection and sensitivity karananand Main CFD Forum 1 February 26, 2010 05:41
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 17:15
Zones with different turbulence model Bert Siemens 0 April 30, 2004 18:09
