impinging jet?
Old   March 3, 2006, 17:47
Default impinging jet?
majesticcc
I am trying to model an impinging jet like cooper's experiment h/d=6. There is a nozzle through which air is exiting vertically downwards with 8.7 m/s and hitting the ground. I have questions about it. what would be the top boundary condition besides the velocity inlet? Is it pressure inlet or velocity Inlet with zero U and V velocities? If I put Inlet condition bc there with zero U and V , then what values do I put for k and epsilon there ?
Thanks
Old   March 4, 2006, 04:57
Default Re: impinging jet?
Frederik
Hi, you can find all details about bondary conditions ans turbulant K-epsilon parameters used in this paper of prof.A.Nguyen he used pressur outlet boundary condition type(is your cas a 2D model or 3D one ?..ans what is the nature og materials(pool) you use in you model?)
http://www.cfd.com.au/cfd_conf03/papers/105Ngu.pdf
Old   March 4, 2006, 05:40
majesticcc
Thanks frederik ı will read the text.ı am using 2ddp axisymetric model and the material is air everywhere in the model.
Old   March 4, 2006, 19:31
Srivatsan V. R.
Hi!
The best bet is Mass flow Inlet, if at all U know the mass flow rate. If not, then try Pressure inlet!
Old   March 4, 2006, 20:16
majesticcc
thanks srivatsan but the problem is ıf ı will use pressure ınlet which turbulance specification method and ıts parameters ı should use.ı dont know how to find correct parameters in pressure inlet boundary condition which is near the velocity inlet(nozzle out).nozzle diameter is 26 mm and height from the disk is 125 mm and radius of the disk is 150 mm.fluid is air. thanks ........
Confined Impinging Jet Geometry furley2372 Main CFD Forum 0 May 31, 2011 21:18
impinging jet natesan Main CFD Forum 3 March 17, 2005 06:42
impinging jet natesan Siemens 1 February 25, 2005 04:16
impinging jet data Andreas Abdon Main CFD Forum 4 January 19, 2000 08:40
IMPINGING JET ........... HELP!!!!!!!! Amir Omoumi Main CFD Forum 10 August 30, 1999 23:11
