SOLUTION CONTROLS??
Old   March 3, 2006, 15:11
Default SOLUTION CONTROLS??
naus
please tell me how to put the right solution controls in
FLUENT??
Old   March 3, 2006, 16:06
Default Re: SOLUTION CONTROLS??
Josh
They are automatically set to 0.001, you can change according to the convergence of the solution.
Old   March 4, 2006, 03:54
naus
I want to say,how to choose the disretization when I do solve-controls-solution:
pressure= standard or PRESTO!...??? pressure velocity coupling= simple or simplec...??? momentum=first order upwind or second order upwind...??? ... thanks a lot for your help
Old   March 4, 2006, 09:07
Rizwan
Go through chatper 24 of Fluent Help tutorial guide. Specifically speaking sections 24.6, 24.7 and 24.8.
Regards
Old   March 4, 2006, 15:05
naus
I read these sections but when I put these values:
1-uder relation factors pressure=0.3 density= 0.8 body force=1 momentum=0.7 turbulence dissipation rate 0.8 turbulence viscosity=0.8 h2o=0.8 energy=0.8
2-descritisation pressure=PRESTO! pressure velocity coupling = second order upwind density = second order upwind momentum= second order upwind turbulence kinetic energy= second order upwind turbulence dissipation rate= second order upwind h2o= second order upwind energy= second order upwind
and I open my file (the next time), I have this message :
Error: Set_Thread_Variables: wta(real) Error Object: ((constant . 0) (profile "" ""))
PLEASE HELP ME WHERE IS THE ERROR ??????????????
Old   March 5, 2006, 03:36
Rizwan
Can you explain what problem you are solving. As a general gudiance i can say that, choose first order before going to second order. and when you initialize the solution make sure that the paramemters for tubulent viscosity and dissipation are relavitely low of the order of about 1e-5.
regards
Old   March 5, 2006, 04:14
naus
I study a ventiled room , I have a natural convection.
I think that I was mistaken in gauge pressure too(in pressure outlet BC),I have put in operating pressure 101325pas and I put gauge pressure = 5pas, because my outlet pressure is 101330pas.
it is right wath I do????????????????????????????????
Old   March 6, 2006, 03:36
Rizwan
yes it is correct. if you have natural conveiton make sure that the domaain is much large so that the walls woudlnt affect the flow inside the domain. i personally have experience about such situation in natural convection.
Integrated conjugate heat transfer solver in OpenFOAM hjasak OpenFOAM Running, Solving & CFD 172 April 13, 2023 01:42
Solution converged, and then diverge again. jrg FLUENT 2 April 2, 2013 00:10
help me in solution controls for a 3-D rudder. bachi FLUENT 1 January 30, 2008 04:33
Questions on Analysis Controls and Runtime Control Arnab Siemens 1 October 26, 2004 10:47
Discussion about Mesh independant solution Seb Main CFD Forum 13 May 22, 2001 14:37
