meshing a geometry
Old   March 3, 2006, 03:43
Default meshing a geometry
vinay
I have a small doubt. If we are meshing a 2D geometry, then, can we mesh one face using quadra mesh and other with triangular mesh? I hope u understood my question. If any clarifications are required I will do it.
Thanks in advance
Old   March 3, 2006, 05:54
Default Re: meshing a geometry
mAx
if you mean, you have 2 faces connected each other, than yes you can mesh one with quad and the othe with tri
Old   March 3, 2006, 07:04
vinay
Thanks for your information
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry mazhar1613 ANSYS Meshing & Geometry 1 January 12, 2012 00:18
Need help on meshing this simple geometry nha1g08 ANSYS Meshing & Geometry 3 March 9, 2011 03:13
Meshing on simple geometry pukiwawa FLUENT 5 August 31, 2008 13:04
Problem meshing turb. blade tip clearance geometry Balu FLUENT 0 June 7, 2008 22:10
meshing geometry in gambit soundar FLUENT 1 January 7, 2005 03:59
