a variance of forces in FLUENT
Old   March 2, 2006, 04:11
Default a variance of forces in FLUENT
changkiang
HI,does anybody find a variance that the lift(drag) value we back-calculated by the lift(drag) curve sometimes isn't the same as that Fluent reports (Reprot\Forces).
regarding.
Old   March 2, 2006, 06:13
Default Re: a variance of forces in FLUENT
Erdem
after the calculation when using the report forces panel you shoul use the right vector directions in X and Y coordinates. if your flow has an angle with the body these value must not be eg X=1 Y=0 for drag. you should input them aligned with the flow direction
Old   March 5, 2006, 02:18
changkiang
well, i follow what u said. and the problem does exist after i set the right vector directions. maybe it is a bug in FLUENT?
thanx you very much.
Abaqus - Fluent Coupling WITHOUT MPCCI s.mishra FLUENT 1 April 5, 2016 07:47
how to get forces on Iso-Clip Surfaces and How to get forces in cylindrical coordinat CFD XUE FLUENT 3 March 18, 2015 04:28
hydrodynamic forces using fluent nims FLUENT 5 February 6, 2012 00:30
forces in fluent carno FLUENT 1 March 2, 2006 06:08
Fluent forces -lift/drag interpretation P Smith Main CFD Forum 2 October 26, 1999 16:00
