Regarding Reynolds number
Old   February 28, 2006, 10:49
Default Regarding Reynolds number
John
I am simulation water oil stratified flow in a pipe of 15 cm diameter.
I have two inlets for oil and water seprately but only one outlet.
flow rates of both water and oil are constant at 5 cubic meter per hour, but I have a very basic problem of calculating the Reynolds number for water and oil separately when it comes to choosing the diameter. should I have to take half the dia (7.5 cm as upper 50% of the pipe vol is occupied by oil) or should i have to take the entire pipe dia for calculating Reynolds numbers of individual phases.
Please advise.
Problem with decomposePar tool vinz OpenFOAM Pre-Processing 18 January 26, 2011 03:17
Reynolds Number and Heat transfer Coefficient panos_metal FLUENT 0 January 7, 2011 07:37
Low Reynolds Number k-epsilon formulation CFX 10.0 Chris CFX 4 December 8, 2009 00:51
Reynolds Number Matt CFX 0 February 25, 2009 06:40
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
